I have been trying to remove the radio from my 2007 RX400 to no avail. I have searched the forum and cannot find anything - it could be that it is in here but I cant find it!
I have taken off the surround from the shift and the small panel above it which houses the heated seats and cig lighter. I can see and have removed 2 x 10mm bolts and have also removed 4 x self tap screws. However, nothing is loose!
Any help would be appreciated...
Thanks,
John
Hi John
I believe there are 4 x 10mm bolts.
Try this link
http://www.clublexus.com/forums/rx-second-generation/227901-vaistech-sli-installation-instructions-w-pics-for-04-07-rx.html
Also, presumably you will have disconnected the 12v Battery before starting this removal(??!!!). If so it would be worthwhile doing the ISC reset procedure so that your MPG doesn't suffer afterwards.
http://us.lexusownersclub.com/forums/index.php?showtopic=58930&st=0
Regards
JBP
