HELLO...I HAVE A 1991 LEXUS LS400 WITH A 1993 MOTOR IN IT. MY A/C DOES NOT WORK...I THOUGHT IT WAS MY A/C COMPRESSOR SO I HAD IT REPLACED AND A/C STILL NOT WORKING...I HAVE BEEN TOLD THAT THE 2 ELECTRIC FANS ON THE FRONT IS THE CAUSE OF THE COMPRESSOR NOT WORKING. WHEN I TURN THE A/C ON YOU HERE THE COMPRESSOR COME ON AND I FEEL COLD AIR BUT THEN IT SHUTS OFF. I HAVE TESTED THE RELAY FUSE AND THAT IS FINE...WHAT ELSE COULD IT BE CAUSING THE 2 FANS NOT TO WORK? COULD IT BE THE FAN RELAY SWITCH OR DO I HAVE TO REPLACE THE 2 FANS? PLEASE HELP...I AM HOT...
Welcome to the LOC.
Could you drop the caps lock please there is no need to shout :D
First thing is who replaced your AC compressor?
I had an auto shop replace it...
