Sat-Nav Not Switching To Night Mode
Hi, a have a 2004 rx300 and the sat-nav screen is not switching to night mode,i have to switch the sceen off at night as it is so bright it is dazzling any one had this problem!
Not sure if it is the same as the 400h but with that you have to turn the dash light dimmer switch down from the "click position" at the brightest setting for the night mode to operate.
Hope that helps.
JBP
