O/s Front Rattle
Deanslug
Every now and again, I get a loud rattle from the front o/s when I go over potholes/bumps. Had the track rod ends changed recently. That seemed to solve the problem for a few weeks, but it's recently started making noise again. The garage couldn't find anything else wrong. Any ideas?
If all your suspension components check out it can be caused by seizure of the brake caliper pins so remove the caliper and see if the pins slide in and out easily and smoothly. If they are tight or seized either remove,clean,regrease and refit or replace them at around £10.00 each.
Oh nearly forgot,welcome to the LOC.
