Constant Battery Light.
I think the charge light is fed off a wire from the alternator so it could as you suggest be a fault in the wiring.
Sometimes disconnecting the plugs and sockets,cleaning, spraying with contact cleaner and pushing back together can sort this type of problem.
Have a look at the diagram on the link below it shows the standard alternator output terminals including the charge warning light.
http://www.familycar.com/Classroom/charging.htm
