Hi
I am trying to find out if i can fit the following wheel sizes to my car. It is on stock suspension and i am not planning to change this.
245 35 20 front and rear
I know i should be using 245 30 20 to maintain the rolling circumference/radius but i want to preserve the ride quality.
Any helpful information woul;d be greatly appreciated.
http://www.carbibles.com/tyre_bible_pg4.html
Obvious answer is obvious - don't go for 20" rims!
If you want to play, you've got to pay, as the saying goes.
The whole point of going low sidewall is to improve corner handling, but with the state of our roads nationwide, I'd not be venturing beyond 19" - not to mention tyre prices jump quite a bit after that.
Bottom line, you can't have your cake and eat it - that's the trade-off for having more alloy than rubber on display.
With the 450h having AVS suspension, then you might find you'll need to have it in comfort mode more often than standard or sport, to compensate for the loss of cushioning the extra rubber currently provides.
