Is220D Door Locking Problems.
theoldroadrat
Hello. Could anybody help me please. I am having problems with my Lexus is220 Door locks. Sometimes when i use my Key fob or the Drivers side door handle all of the doors unlock just as they should. Other times only the Drivers door will unlock and the other doors just click three or four times. I have tried reprogramming the car with the key fob and sometimes it works and sometimes it doesnt. The `All door lock` switch inside the door has also stopped working correctly. It will lock all doors but it will only unlock the drivers side door. When i mentioned it at my local dealer i was told it was probably the `Door lock control module`. If this is the problem then does anybody know where the door lock control module is located and how to change it. Or do you think it could be something a lot more simple to sort.
Dean.
  • 1 year later...
  • 9 months later...
