Is200 Cutting Out
Dave_R
I have recently been having a problem with my lexus cutting out when it gets warm, there is no warning just dies. It starts after but the revs immediately drop and it cuts again. When cool it starts and runs for a little while longer.
When I read the codes there were 2 errors, 1 was the input sensor into the auto gear box and the other P1325 Igniter Circuit Malfunction (No. 6). I replaced the sensor and have a replacement coil pack but, sounding stupid now, I realised that I haven't been able to find a diagram anywhere to tell me which coil pack No.6 is.
Before changing it I reset the codes and drove it. It cut out again when it got warm and there is now only 1 code in the system....p1325. Would anyone happen to have a diagram to tell me where No.6 is or be able to point me to a link so i can see it? It is an annoying fault as you can't trust the car at the moment...and probably won't for a while after either.
Thanks in advance
Dave
I am suprised that on a six cylinder engine a single coil pack can cut the engine....you would have thought it would have simply misfired. I guess you can never tell what the engine management system is going to make of it so lets hope that it cures the problem!!!
