Is200 Front Fitting Kit & Anti Squeal Kit
asharb123
I have a fear that my IS my not have the full front fitting kit & anti squeal kit, as my front pads are moving in the calipers (there is a knocking sound from the caliper) and I get a scraping / grinding sound when I brake when the car has warmed up and driven for a longer time.
Remembering back to when I had to have a couple of the wheel studs replaced it did not look like there where any pad support plates or any anti squeal shim or inner anti squeal shim's.
Is the front fitting kit & anti squeal kit only available from Lexus?
Hi if you look on the Livingston Auto parts web site; they list a fitting kit APKIT 1059 which is cheaper than the lexus set .
With regard to your post on slider pins ,I have not been able to find an alternative supplier .
hope this helps
