Altezza As200 Beams 2000 / Is200 Wiring Help!
Ryan3832
Toyota Altezza As200 / Lexus Is200 Wiring Help!!
Ok got a Toyota Altezza As200 Beams 2000 other week
this is the 1GFE beams engine 2litre straight six as far as i can tell same engine as Is200 car drove fine for 2 days then went out to start it and nothing at all thought Battery was flat tried booster pack nothing got a mechanic friend to look at it basicaly had key turned ignition was on and there was a few lights on dash but no Battery light etc but if you put your foot on brake pedal it brought all the lights up so he suggested Dodgy wiring/loose connection somewhere
i checked all the Fuses in engine bay all fine and in both fuse Boxs in both footwells all fine there too when we checked the car the next day the Fuse box in the passenger foot well was soaking and this was because some1 ran a subwire through rubber bung in bulk head water was running down this and into fuse box so took fuse box out completely dried everything sealed up bung contact cleaner on all connections got car turning over but wont fire so now we think this is definatly an electrial issue then got car going but wouldant rev properly
i have been asked to get a Pin Data for the ignition Switch?
and also a general wiring diagram for the car if possible
and if anyone know what exactly runs through the fuse box in passenger footwell that would be greatly appreciated Thanks
If you send me your email i can send you all wiring diagrams, if one of the fuse boxes was soaking wet could still cause problems even when dried, electronics dont like water. I have one if needed £20 posted to you.Id start with this first before ign ect.
I have (ALTEZZA import) lexus is200 year 1999 miles around 51000 mark just few days I've had something gone wrong which is difficult to understand.
Driving coming towards traffic light slowing down just then the car started to shake and cuts. No engine management light come on I started the car which started first time then again slows down car does the some thing again shakes and cuts off. I've done full service but still the some when engine cold it's ok but I noticed revs shots up to 2000 and down and up automatically when ever the engine hot.
I've also cleaned out the throttle body sensors too. It seemed ok but driving again engine hot coming towards light shaking started and cuts off I hav to quickly gone done too neutral and revs shots up put back to D drive revs go right down like going to cut off but doesn't cut off.
Please please pease help if anyone come across this before or anything I can try.
