Is200 Radio (Fm Fault)
Hi Guys & Girls
Could any elec techys advise me on my problem.
The FM side of it has packed up, it just keeps scanning for a station.
The MW/LW is ok and so are all the other functions.
Should I be looking at the amp or aerial?
I've got the 2000(W) IS200SE
Thanks in advance
The is200 aerial is a powered one, so it has a 12v power supply to it, so that may have come adrift, also if its a non lexus head unit then find the black aerial cable follow it back into the dash to find a thin black wire that come from it and feed it 12volts and you'll be golden...
