How To Paint Calipers
My son did mine with a wire brush first, then give them a blast with brake cleaner and then use high temp paint.
One thing he always does is remove brake pads and clips ect, hate to see them painted only do caliper and carrier. paint is available in other colours, found the seller excellent
http://www.ebay.co.uk/itm/SILVER-HOOK-HEAVY-DUTY-BRAKE-AND-CLUTCH-CLEANER-500ml-SGBC1-/320892772737?pt=UK_Car_Accessories_Car_Care_Cleaning&hash=item4ab6b32181
http://www.ebay.co.uk/itm/FERRARI-RED-BRAKE-CALIPER-PAINT-METAL-STEEL-ENGINE-High-Temperature-125ml-Tin-/160958550737?pt=UK_Body_Shop_Supplies_Paint&hash=item2579e092d1
So because you have to do each one individually how long should I give each one to dry? Because I'll have to jack each wheel up at a time.
I saw a tutorial on here on how to change calipers so the same will apply on how to take the clips etc off right?
I'm thinking orange....to go with gunmetal body and alloys....thanks for the links.
The paint covers in one coat and if the weathers like today it's gone off enough to re-assemble with care in 30 mins. if you have a pair of axle stands you can do both fronts at same time. Rears are easier as you only remove pads not caliper.
