Need Help
Bens is200
My is200 ran fine this morning went to start later and it's running rough engine management light and flashes when driving is on no power like its in limp mode revs fine idles fine exhaust is very hot and inside gets hot to with no fan or heating on I changed plugs for new ones Iridiums about a week ago one before were the same but not sure what's the problem and can't get hands on a scanner any help would be greatly appreciated
It's very difficult to help without OBDII codes, could be an investment you should consider for around £50.00.
Only thing I can suggest is recheck your recent plug change work including the coils for damage and wiring to them.
Just finished taking them back out checked them all making sure there fitted properly retightened them then I removed each coil plug lead and started car on each, car died so coils are all working cheched for breaks in cable or fittings on the coils and they all seem good just wondering if its a throttle body sensor or the throttle body needs cleaning still don't see why that would affect the running
