Advice Please. Bushes
Stuart Aspey
I have been told by my mechanic that I need a new nearside rear lower control arm rose bush. Is this actually what it's called? Does anyone have a part number or a diagram of the rear suspension to point out the bushes.
Also. Hello again.
not sure how to bring the diagram up but its a round bush that sits below the hub.
on the track control arm you got the link bar which runs through then the shock damper & the hub bush or control arm bush.
this bush sets up the rear geometry.
your car must be fishtailing if this bush is worn with play :yawn:
