Battery Clamp
Gaz31
Hi, I've just picked up my IS220d and found that the Battery has been replaced but the clamp was just resting on the top. I have two pieces, the bit that lies on top on the Battery and the long rod that runs down the front of the Battery. I think there is a piece missing at the back, does anyone have a picture of how this fits normally?
Thanks!
That's not good, the Battery needs holding securely.
There should also be a holding rod at the back of the Battery. It is shaped like a walking stick and locates upside down into a slot on the bulkhead. This then attaches to the top clamp. It may be down the back of the Battery. It can be a little fiddly to attach....but attached it should be! I guess the top nut is lost but that's easily replaced.
