Hi there, I'm have had a search on the forums before I posted, but that doesn't mean I'm not missing the info.
I was working at the car & removed the door handles.
Then when I was finished I locked the car with the key & I think I pressed a button twice, I really am not sure.
I tried something, opening a door or pushing the door lock rods(door handles are still off) & the alarm went off.
I tried to turn it off with the key, but it wouldn't work.
I opened the windows with the locking rod & put the key in the ignition to start the car, thinking that this would reset the alarm, but no joy.
The only way I could get the alarm to turn off was to disconnect the Battery negative, but every time I reconnect it the alarm goes off.
Does anyone on here know of this happening/how to fix it??
I would really appreciate any help as the car has to be moved soon.
Cheers.
Try this Irwin.
1 turn ignition key to the "lock" position and remove key
2 Close and lock all doors inc boot and bonnet, wait 30 seconds till security indicator flashes
3 Insert key in front driver or passenger door and unlock, security indicator should flash twice confirming alarm reset.
Hi Ian,
Thank you for your reply.
I didn't need to do this as strangely I got it sorted first thing this morning.
I now think I know what the sequence of events caused it & sorted it.
I put the door handles back in & reconnected the Battery, but whilst I was putting the passenger side handle in, I unlocked it with the key before even connecting the Battery.
Then when the Battery was connected all I had to do was press the unlock button on the key & it reset.
I have worked out that if you press & hold the lock button on the key the alarm will arm & eventually beep.
But, if you press the lock button twice, it seems to put the system into a state that only a manual turn off the key in the passengers side will allow the remote to work again.
A lesson learnt no doubt.
Cheers, Erwin.
