Trottle Control Moter Lock Malfuntion
Martin, look very carefully to see if any vacuum lines are uncoupled or damaged. You will need to remove the engine cover. On U.S. cars your problem throws up the code P1128 which refers to the throttle control motor lock. (Our cars are not as strictly OBD2 compliant as the U.S. cars, so harder to read, and expensive at Lexus). An owner there had this code and it turned out to be just a damaged vacuum line. If it is, it's an easy fix.
will check that out , the mechanic is a polish lad and is good , he said the motor moves 2 mm either way,if any one here can direct me to a second hand one i would to extremly happy.wifes car my one if fine and that does not go down well.
