Fuel Cap Won't Open Is200
I had trouble with mine when I first got it, the bit around the screw cap is fairly flexible, mine just took a bit of mauling and messing with the spring to get it to function
In short, I strengthened the spring by widening it a little, this made the actual outer flap not quite flush when closed, I then moved the flexible inner part where the release pin is so it sat a little further in
I had the same problem. I found a piece of the spring had broken off by the petrol cap. I now have to prop the lever up with a block of wood & open the flap with my credit card.
