Torque For Android Readings
I received today my OBD2 ELM327 V1.5 Bluetooth Car Scanner.
I connected to my lexus IS220 and i get the fallowing results:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 35335500
Test report:
MID:$21 TID:$ad
- Catalyst Monitor Bank 1
Max: 6,553.5°C Min: 70°C
Test result value: 208.7°C
PASS
MID:$21 TID:$ae
Test result value: 191.2°C
PASS
MID:$31 TID:$b8
- EGR Monitor Bank 1
Max: 655.34998g/s Min: 0.95g/s
Test result value: 0.15g/s
FAIL
MID:$31 TID:$b9
Max: 655.34998kPa Min: 6kPa
Test result value: 7.05kPa
PASS
MID:$70 TID:$2b
Max: 24,695 Min: 6,881
Test result value: 65,522
FAIL
MID:$f0 TID:$05
Rich to Lean sensor switch time(calculated) -
Max: 28,716 Min: 7,057
Test result value: 65,523
FAIL
End of report.
I supposed the first one is about my EGR valve which is clogged and needs to be cleaned.
Can someone explain what is the meaning of the other 2 FAIL tests and how can i fix them?
Thank you.
This is the new readings for today.
Maybe someone can help me understand them.
I read on a forum that if i want to understand those readings they need to be in conjunction with some Pxxx codes, but when i try to read the ECU fault codes it tells me that I have no errors stored in the ECU.
Test report:
MID:$21 TID:$ad
Test result value: 202.5°C
PASS
MID:$21 TID:$ae
Test result value: 177.5°C
PASS
MID:$31 TID:$b8
Max: 655.34998g/s Min: 0.83g/s
Test result value: 0g/s
FAIL
MID:$31 TID:$b9
Test result value: 6.52kPa
PASS
MID:$90 TID:$07
Minimum sensor Voltage for test cycle(calculated) -
Max: 287.13998% Min: 70.57%
Test result value: 655.22998%
FAIL
MID:$90 TID:$2b
Max: 24,686 Min: 6,881
FAIL
End of report.
