Headlight Dismantle
Hi, I'm just wondering if anyone here has used the oven method to take apart the headlight units on an Is200.
I've only read up on it so far, does it work ok without damaging the light unit? I need to replace the beam shield in my projector. Any help would be appreciated.
Thanks.
Deano
Hi mate i have used the oven method to split the headlights. Preheat the oven to 110 deg C. Put the headlight in the centre of the oven, leave the headlight in for 15 mins. Remove headlight and gently pry the headlight apart starting at the end opposite the indicator. The corner that would be by the grill. I used a knife to pry the light open.
