Heating / Ac Delay
MrChopsy
Hi
When I start the engine on my 2007 IS220D, I have to wait for about a minute until I can turn on the heater / air con, is this a normal thing ?
Also when I turn it on, it always resets to 22 degrees, is there any way of changing this ?
Chopsy
Guest bigbullhead
As above but adding ,if you want more heat/flow put on the front switch it speeds up but I turn temperature up to 28 for 5 mins prior to leaving work although going to work is easy as I garage it
