18 X 8 Alloys.
DarrenA
Size isn't a problem but you want 114 pcd and a 5 stud configuration. Offset is 42mm desirable but I get away with 32mm.
Arch rubbing shouldn't be an issue if you have stock suspension. 18s should give a fairly good ride, 17s are best though.
i'm running on 18's with 245/40zr tyres , you have got to have the correct tyre profile or your speedo will read incorrectly, there is a site smewhere which gives wheel/tyre ratios to give correct speedo readings ,it also gives the errors i know mine are supposed to read 59.9 mph at a truespeed of 60 mph and thats close enough for me,
sorry ca'nt remember the site ;)
