feed electrics behind dash
ok i desperatly need the locations and colours off...........
Permanent live.....
Switched live........
ilumination live(taking from dimmer switch.....but which wire)
i need this info asap please
mat
Try the wires to your clock, they should have Permanent live, Switched live, ilumination live just use a meter to find out which is which.:D
was for my HKS gauges.............
ive done it now.........i initially ran them from the fog light/washer/leveler switches but some bizzare crazy stuff was happening with the headlights.............
so ive run them straight from the perm live and switched live behind the ignition socket.......illumination is from......headlight washer switch.......
if anyone needs the colours ,let me know....
