Guys,
Been searching high and low and cant find much on how to remove the air vents in my GS 450h. Do any of you know anywhere I can find out the process please? interested mostly in the center pair and the drivers side.
Wayne
Looking at the exploded diagram it seems that they are a push fit so a narrow wallpaper scraper wrapped with some insulation tape usually does the job. Insert the blade a few mm at the bottom and push the handle down once the vent begins to move swop to the top and push the handle upwards. Once loose it will wiggle out.
Thanks Steve, so no screws at all? and no other trim removal? can you tell me where you found this exploded view please as ive been searching for ages and Lexus want to charge me an hour per vent..
