Wheels In Motion
Adie
I visited Tony this morning for a full geometery and to sort out a problem I had with the car pulling to the left and steering wheel vibration at speeds between 45 mph to 60 mph. It turned out that the wheel was extremely out of balance, hence the vibration i was feeling through the wheel and through the drivers seat. I also had some adjustments done to the camber of the car etc, through the geometry.
Driving home, it was unbelievable how much difference there was in the car. The handling was a lot tighter and the car more responsive. Also no more pull and no more vibration.
All in all I recomend everybody to have a geometery check done to sort out the handling and tyre wear and overall drive in the car. The difference is that much! Tony comes across as someone that cares about what they are doing which is hard to find these days. A top job done by a top bloke :D
@ Tony i've tried to explain about what was done to correct the vibration on a 5 stud plate but couldn't do it justice. So if you could please add what was done and all terminology much appreciated.
Thanks again mate
Adie
I think tony should have his own Forum ............  :whistling:
That reply far exeeds any forum, a problem, a customer, a result, LOC for me is home. an area where things that cost £sssss can be addressed easely, just dont ask me anything about your "turbo" :blush:
