lowering lexus is200
jatt300
there are many suspension systems out there
springs,dampers and coilover(spring and damper in one)
for springs alone your looking at a anything +/- £200,these will lower your car anywhere between 20/35 /possibly even 40 mm
coilovers cost anything from £2000 +
but these will lower the car all the way down to 80mm
If you uprated the springs to no more than -30mm on relitively new dampers you should have no problems, but if you've done a lot of miles you would be better to uprated the dampers. If you want to go lower you will need to uprated them to shorter items to stop you riding the bump stops all the time. Also get a Lexus dealer to check your alignment after you do anything.
