Best Polish For Black
ALI_1
Hi what is the best polish for a black car also do certain polishes work better on certain colours
Black is so hard to polish as you see every inperfection in the paintwork.Also it very hard to put on a even coat of polish by hand as you need a even coat to get a good result.What you need is a electric polisher.This helps to even out the polish,remove small scrathes and swirl marks.You will be amazed at the results by using a polisher plus they are so easy to use.
