How Do I Change A Number Plate Bulb
Sorry if it sounds like the first line to a cheesy joke,but I am stumped. I have tried from the outside by prising the lamp holder out but no luck. I was then told by a mechanic friend that I should be able to access it from inside the boot lid. I have removed the little "press stud" type clips and two small nuts either side of the boot lock cover but no luck still can't gain access. Looks like I need to remove the two bolts holding the boot lock in place which I don't fancy doing. Must be an easier way? Any assistance most welcome.
