AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
steveboiboi    1
Basically I want to fit a different steering wheel and I know if I take the factory one off the airbag light will be on therefore disengaging the entire system... Just wondering if anyone has done or if there is a module you can buy to keep the system in check with the drivers airbag removed? Or can a resistor be put in place? If so how and if anyone has a wiring diagram that would be ace... Cheers
JollyRoger    0
Taking off the Air-Bag will not dis_engage the whole system, but it will put the light on the Dash, I'm not sure about the diode but could work if wired properly,
You could also pull the bulb in the dash cluster,
Air-bags aren't as good as you might think, I work with accident damaged cars and it would surprise you what it takes to set them off,
I have seen cars slaughtered with the bags still intact and seen little or no damage with all the bags discharged, so don't be expecting them to save your life.
Seat belts are a far better option.
lex2oos    1
2 ohm resistors is what u need. simply connect them and thats all.
or.... you can rewire and put em under your seat and in case if they set off you'll be sky high
steveboiboi    1
Sweet looks like I'll be looking for a boss now then! Cheers guys and about the amount of force to set a bag off... Well quite embarrassingly I've punched the midle of the steering wheel and set the bag off before! Big mistake!
Monster-Mat    11
on the is200 if you disable the airbag it shuts the whole system down, you can not use a resistor in the system, i have tried all options in the past, in the end i removed the airbag system
you can only use a resistor mod on the seat airbags
Brixeylexus    0
If you remove the bulb won't it still fail MOT as you can see the bulb is not in if it doesn't illuminate when you turn on ignition?
NemesisUK    485
How does a modification like this sit with roadworthiness, type approval and insurance?
Britprius    399
I do not see how this would make the car unroad worthy after all you can turn the passengers air bag off in most cars with the switch provided. I do agree that changing the steering wheel to one without an air bag would be something the insurance companies would frown on.
John
