Double Din Facia Kit & Wirring Adapters
I have a 1995 GS300 and i have finally decided to change the stereo after the factory unit stopped working several months ago.
Does anyone have any advice on what cable adapters i will needand where to source them, also facia unit. every one ive tried so far only stock for the Mk2 (1998+) not for the Mk1 (1995).
many thanks
There was a thread on here a couple of days ago in the GS300 section. The ones shown were authentic Toyota for the Aristo I believe. They look great.
As for the cables, best person to tell you is Tigerfish.
Ive not seen any aftermarket double din kits for a right hand drive mk1 GS300, all of the autolead type ones have always been lft hand drive. Toyota do one for the aristo, there are some part numbers in my signature link for the "mk1 Single Din Install". I made my own bracket, but I suspect there is a Toyota item. The tricky bit is knowing what to order 'cos the parts diagrams are pants. When I did my install, I couldn't fins any adaptors, and as I had no plans to revert to factory headunit, I just cut the connectors and fitted ISO plugs to the factory harness (So I could connect the parrot handsfree kit in as well). I bypassed the amp in the boot so that I didn't need to run new wires to all the speakers.
Oops My bad. It was on an Aristo forum I saw the fascia. Not sure if I can post a link to another site so have copied it in its entirety.
MK1 Aristo (JZS147) Facia Panel
for RHD cars
Fascia Plate Part No 55412-30430 approx £15 + vat
Cubby box - Part No 55521-32011 approx £23 + vat
You need to work out what brackets you need, one is for single, the other for double DIN
Bracket 1 RH
86211-30170
86211-30200
Bracket 2 LH
86212-30150
86212-30170
Hey i have a 1993 Aristo and i need a double din install kit with brackets and facia kit , let me know if you guys can get this for me . If you can my email is kingcharleshaha@yahoo.ca . I am in Canada and i am willing to pay the shipping if you guys can hook me up . Thanxs alot
  • 4 months later...
Hi all I'm new on loc I own my second gs300 mk1 I'm running 19" alessio f1 wheels trying to find cheap coilovers I gave up looking for after market radio leads so I stripped the whole pioneer system out now running alpine 4 channel amp driving door speakers and in the boot is a Orion hcca 12.2 sub both amps in boot it can be done
All I need now is double din face plate
Just go to your local Toyota dealer mate, the part numbers for the double din fascia are posted further back in this thread.
