Hi All,
does any one know if the ABS/Speed sensor units from MK2 GS300 / LS430's fit GS430's ? my front right ABS unit is faulty and have been quoted almost £190 from Lexus for the part. still waiting on a quote from Amayama Ltd but have seen a few GS300/LS430 being broken on eBay and wondering if these parts will fit? Thanks
yeh just received emails from two lexus branches quoting the same part number for GS300 and 430 so its the same part for both models.. found a guy breaking a GS willing to sell it for £40 he confirmed its in good working order and asked if he will fit it and he says £20 for fitting so might just try him out and see how it goes if not might aswell order from Amayama or Rock Autoparts. Thanks
If you use toyodiy.com you can find the part by selecting your vehicle. Then once you have the part code you can search for that across all vehicles.
From what I can see the part is common to the GS300 and GS430, and also the SC430. The LS uses a different part.
my wire tore completely from the unit and wasnt sure how much hassle it to replace just the wire to the unit. only cost me £40 to replace from the breaker so cant complain when considering a new unit from Lexus would have set me £190 for the part.
