Cleaning The Satnav Display Screen
PhilipK
I've just bought an E93 BMW M3 with a (non touch screen) sat nav fitted. There are a lot of marks on the screen, and reading the BMW forums this is a common problem, caused by a fragile Anti Reflective Coating which is easily scratched. The only solution (other than replacing the whole screen, which is not cheap) is to use a product like Novus Plastic Polish to remove the rest of the coating, and then possibly to install a screen protector (like the ones you use on your phone).
This got me thinking - what should I use to clean the touch screen on my IS250? Normally I would have used a screen wipe (like I'd use on a computer monitor), but after seeing the issues with the BMW, I'd like to be sure.
