Vsc Warning Light On After Cleaning Egr Valve
Dpf was removed and an emulator fitted 7 months ago .... was time to clean the Egr ... only used liquid cleaner, no scrapping but when reassembled and driving after 15 mins the Vsc, engine light has come on ffs
Checked Egr connector and cleaned it
Any ideas guys :(
Try resetting by disconnecting Battery when had my dpf cleaned was advised not to remove it as lights would come on sooner or later but it's been 7 months since u had it removed had any issues????? Could be egr fault.get codes I'm sure some one on site will be able to help good luck
Emulator is fine, it was the egr valve, i took it apart completely this time by even removing the solenoid. .. valve was sticky even though i had cleaned it completely, as i could push the valve in i got to clean it 100%,.
It worked, no warning lights
