Next Generation Ct200
Desmond
I was reading a review of the new Prius the other day in which it mentioned it has occasional 4wd by means of a separate electric motor to the rear wheels. Wonder if that technology will find its way into the next CT200?
Has anyone seen any gossip about when that model might be expected?
You may find it will be a Full hybrid. System uses engine to drive front wheel & e-motor to drive rear wheels.
Current set-up only drives front wheels via engine & e-motor on front axle.
Full Hybrid allow AWD feature where required.
