Need help ASAP
andrewmeisman
So I went threw what I thought was a little puddle unfortunately it wasnt.... it hydrocodone the motor pulled the spark plugs dry fired ect... there was fuel in my oil so did a oil change immediately put new spark plugs in sprayed a lil either and it ran like a raped ape..... next day it wouldn't fire Haddad either it again got it to my shop then it went into limp mode turned it off and it wouldn't start pulled spark plugs dried em it turned on but after getting hot it started revving crazy from 2k up to 5k so I turned it off red the code it says pedal position sensor well I took the tps off to adjust it and cuz I was hearing a clicking noise from the throttle power module but now the tps won't line up correctly when I out it on just to get the bolt in its at lije 3 k well I decided to just leave it off and it idles at about 1 in a half I took it for a test ride it shifts hard when u put it in gear and won't go into m mode at all im so infused ecu? Throttle body? Or both or just a stupid sensor idk and I had a new maf in
Sent from my C6740N using Tapatalk
