Where is the power steering pressure sensor
  • 6 years later...
Error codes c1511 and c1512 -symptom no power steering. (Torque sensor 1 & 2 respectively )
lexus told me that there was no communication through the car to the ps  and they provided me with the above codes.  Said this was a major job done from the inside of the car and the power steering rack would have to come out to see if it was a wiring fault or something else.  This was all as a result of crossed Battery terminals when jumpstarting.  I had replaced the fusable link which blew, the 150a fuse blew but not the 80a ps fuse, plus the 4 x 20a door fuses and 2 x 10a audio display fuse  + a 30a audio fuse as well.
A search of the internet returned the following:-
DIAGNOSIS CODE SET CONDITIONS
These diagnosis codes are set in the following cases:
C1511: Torque sensor main system malfunction
  • The torque sensor main output voltage does not agree with the predetermined voltage stored in the microcomputer, and the microcomputer determines that a problem has occurred in the torque sensor main system.
C1512: Torque sensor sub system malfunction
  • The torque sensor sub output voltage does not agree with the predetermined voltage stored in the microcomputer, and the microcomputer determines that a problem has occurred in the torque sensor sub system.
lexus told me that there was no communication through the car to the ps  and they provided me with the above codes.  Said this was a major job done from the inside of the car and the power steering rack would have to come out to see if it was a wiring fault or something else.  This was all as a result of crossed battery terminals when jumpstarting.  I had replaced the fusable link which blew, the 150a fuse blew but not the 80a ps fuse, plus the 4 x 20a door fuses and 2 x 10a audio display fuse  + a 30a audio fuse as well.
Check out this YouTube video - excellent
"Not the Power Steering module, 2008 Lexus IS250 with C1515 and C1525"
