Hi got trouble with 6 speed auto box on ls430 bumps into 5th gear then dosent change into 6 th even on 40 miles run , did paper clip test faults on vsc came up 43 51 62 63 took in for service said that a solenoid fault shows but lexus didn't have any solenoids available till march will solenoid cure or is it rebuild replacement any help appreciated.
Check your coolant colour is nice and red - and there is no oil contamination - the LS radiator is also a combined atf cooler aswell and sometimes the Inlet and outlet unions for the atf rust allowing water and atf oil to mix therefore causing gearbox problems.
