:question::question: does anybody know how i can remove the steering wheel without setting the airbag off.............................? :question: :question:
is there a switch of some form that i can turn it off ?
also how does the shift lever remove ?
best option is to remove the negative wire from the Battery. just make sure you have the radio code if it needs one
there's a nice wheel removal guide in the knowledge base for the IS series im sure the same info is usefull to the GS
