Sign in to follow this
UKDarkstar
GS450h abs error prevents battery check
Bit of a weird one so interested to know if anyone has come across this.
Got my 2010 450h at the beginning of Dec from independent trader (good rep). They agreed to pay for Battery check but when they took it to main dealer were told that a reset had been performed and the car needed to do a couple of thousand miles before they could perform the check.
I’ve now done the mileage so it was in for the check but they advised it couldn’t be done because an abs error was showing. They checked brakes and all was ok but couldn’t clear fault.
Now has to go back for investigation (under warranty from trader) but I can’t think why an abs error stops a Battery check ???
Anyone any thoughts ?
Sent from my iPad using Tapatalk
I'm sure the two aren't related in any way but part of the test is making sure there are no active error codes stored in the ECU.
Issue resolved. There was a faulty connector on the abs module and this was preventing the code check for the Battery test. Dealer sorted connector and now a fault-free Battery test, yay !
Kevin is yours the facelift version with the full chrome grill? - 2010/2011 cars are very rare
