Normally that sort of noise is a drive belt slipping. I believe the 220d as a single belt that drives all the ancillaries which also has a tensioner. Best to check the belt and tensioner are in good condition, if they are then I'd make sure the water pump isn't starting to seize.
+1 starter ... I had similar issues on my renault 19 years ago.. sounds like it it trying to spin up the starter motor before the solenoid has engaged the cog to the flywheel. ... for my Renault I stripped the unit and re-greased the solenoid part (was dry/sticky) .. was fine after that.... (pity about the rest of the car!)
