Ailandas
Intake Cover Gasket Sizes 2jzge
So got a set of gaskets for the intake side and the exhaust side on my 2nd gen GS300. I gave the supplier both my VIN and car reg numbers and they said it would fit however, as you can see in the pics, the gasket on the intake side does not fit. I cross referenced the part numbers and it seems like they are the same as the OEM gasket part numbers. Any idea why that would be the case and any idea how I could source the correct ones fairly soon?
No idea, the same part was used on the series II throughout its life (1998-2004). Must just be the incorrect one in the packet? I think the exhaust one is longer, maybe you had two the same?
Correct part code is 11213-46030
Thanks for the reply! Would that not mean that the curves by the screw holes would not align then?
