So today I decided to check the rear brakes as one of the calipers seems to be binding. Put the jack under the car and started lifting, then only a couple of cms up the car went back down.
Took the jack off and checked underneath: https://1drv.ms/f/s!AkpCntm7XIBuhOJOy6tI3WslFy97fw
Luckily the wheel was still on, and even more luckily I wasn't under the car. So remember folks: always use stands, even if the rust seems insignificant.
Well I cant see your picture but I doubt you positioned the jack in the correct spot and if it does look dodgy place it somewhere on the main chassis.
It's the place the manual says to use, with a visibly reinforced (i.e. thicker) weld. And I used the jack that comes with the car.
It cracked because of rust, plain and simple, otherwise it would have bent.
Just a note on that link Luca.
First, if you click on the 'chain-link' icon on the toolbar, you can enter it there and it becomes an active, clickable link like this https://1drv.ms/f/s!AkpCntm7XIBuhOJOy6tI3WslFy97fw rather than someone having to copy and paste it into a browser. It's not a big thing, I know, but just thought I'd mention it.
However, what is a big thing is that because your picture is in OneDrive, we need to sign up for a Microsoft account to view it. You may be better putting pictures up on a public site like Photobucket, Flikr or Imgur; or preferably just upload them directly into your post here on the forum.
1 hour ago, Hazzo said:
Well according to this online haynes the jack point is forward and inside of the sills like this:
https://reader.haynes.com/en-gb/cars/lexus/is/1999-2005/jacking-vehicle-support/
That's a generic pic, as per description: " Using the jacking locations as specified in your car's handbook [...]"
There's no Haynes manual for the IS200, AFAIK but happy to be corrected as I searched for a while. However there's this Lexus document which is a bit clearer.
008 lift and support locations.pdf
Herbie, many thanks for pointing it out: I completely missed the link button and assumed it would become an active link automatically - my fault.
However I'm a bit surprised that you'd need to sign up, as I made the link public. I'll double check next time I do it.
It was something I found online, I did have access to a full workshop manual online but lo n behold today my access is denied.
  • Club Hybrid Poll
  • 296 Hybrid Reliability
    1. 1. If you were to consider buying a Hybrid model over 5 years old, would you be worried about the reliability of the Hybrid system?
      • Not really as Hybrid systems are always reliable
      • Not if it had a Manufacturers Warranty on the Hybrid system
      • I would not buy a Hybrid model over 5 years old
