DAB Radio adapter.
Alfalfa
On 6/22/2019 at 11:40 AM, Alfalfa said:
Do someone know if this unit wil work on Lexus is 250.  2006. What is EMV?
You can buy the genuine dab antenna and install it. The only difference is your button wont say fm/dab inside the car but you will get the stations (unless you can be bothered to replace that too. Not sure how much it will cost but main dealer offer  service
  • 2 months later...
EMV = Electro Multi-Vision = in plain speak...a large screen, as opposed to the small 1-line LCD screen on the non-navigation units  🙂 So...looking at the example picture they've used...its showing an EMV unit...while in the text it says "without EMV" 😄
But to answer your main question...the OEM retrofit DAB-kit (That also does not have DAB+ support) that you've posted will not fit on a 2006 IS I'm afraid. On the IS...only the 2010 - 2012 models can be retrofitted with DAB using this OEM Toyota kit (without DAB+) or this new aftermarket kit that behaves the same way...but that has both DAB and DAB+
Quote
