Hi
I need to replace abs rings on rear drive shaft of my Lexus gs300 (1998). They have worn down and when I come to a stop, the abs buzzer sounds. Ive been told I can replace the ring or entire drive shaft. I will try for the ring but I want to ensure a) it can be removed, and b) I order the right part. I am having difficulties removing drive shaft spindle from hub. Ive removed brake calipers, bolts nuts from arm joints (except one located at top of wheel arch, awkward to get a good grip and dont want to round the nut off).  I have taken to a few garages and main dealer but not much help. Ive removed hub nut and tried hammering the centre point through.
