interior fusebox location
Hi all, I have a UK 2007 rx350 and cannot find the interior fusebox to install a constant feed to a new dashcam. I have looked online and the advice seems to be that it is on the drivers side under the steering column but it's not there, I have a knee airbag assembly there. I have checked passenger side around glovebox area also.  Surely a fusebox should be easily accessible!! Would be grateful if  someone could advise where else this interior fusebox should/could be located.
Thanks in advance
7 minutes ago, Herbie said:
There are only three locations - engine bay, and both drivers and passengers footwell. Look up behind the glovebox for what you want.
Hi Herbie, thanks for that, found it under the glovebox tucked right up behind on near side.  You need to be a midget contortionist t see it let alone access it.
