peasoup39 14 Posted December 17, 2020 Share Posted December 17, 2020 Have a n issue with VSC light coming on. When i start the car the lights go out. drive 5 yards and they come on. Had them checked on diagnostic and no electrical faults could be found either when stationary or when mobile and all sensors worked electrically. Had a test redone at another garage and on mobile test all graphs stayed the same. however it did then show a fault code. C1336. Zero point calibration of deceleration sensor undone. Can someone explain what this means and how it can be rectified. Did try to get one of the sensors out to check the reluctor ring but it was stuck and made of plastic so i did not want to break it if it was not at fault. I have been advised that the chances are it is a split or corroded reluctor ring but it is annoying the tests could not highlight which wheel is causing the problem Quote Link to post Share on other sites
DocT 27 Posted December 18, 2020 Share Posted December 18, 2020 I'm pretty certain it won't be the reluctor ring, although this can be a problem on the SC430. The calibration of various sensors can be lost for several reasons (lost power, connection of OBD reader, etc.). However, the fix is easy and free! 1. Park the car on a flat, level surface with the steering straight. 2. Ensure ignition is OFF. Find the OBDII port under the steering column (it has a captive plastic cover that pulls off). 3. Loop pins 4 & 14 (see attached pic). A paper clip is ideal. 4. Turn ignition on. VSC and CEL lights light. Wait for VSC light to flash rapidly. This has reset the sensors. 5. Turn ignition off. Remove link. Job done. I have made a reset tool to make the job easy but an OBDII extension lead is also a great help as it removes the need to count backwards while on your back looking up! I hope this is helpful. 😊 1 Quote Link to post Share on other sites
2ddesign 63 Posted December 18, 2020 Share Posted December 18, 2020 Hi as above but a YouTube video of the above procedure🙂 1 Quote Link to post Share on other sites
peasoup39 14 Posted December 19, 2020 Author Share Posted December 19, 2020 Oh i do love forums. The combined technical knowledge is boundless. All you need is the right person to read you post. A contributor once described these little procedures as a "lexus dance". I have tried two before. First to programme a key with the accelerator and the brake. That failed. Next it was to get rid of the beeper on the seatbelt that was sounding off all the time. That failed also. I am happy to say i have at last learnt one of the Lexus dances. Tried the procedure above and i have successfully reset the zero point and lights are out. Thank you both for your great assistance. 1 Quote Link to post Share on other sites
