RX450 2013 only drivers window working
1 hour ago, Filandcaff1 said:
Yes, the battery was disconnected multiple times because the car would not switch off after pressing the power button.
After the Battery has been disconnected you need to reset the windows (not sure about the rest).
From each door itself put the window all the way down and hold for around 3 seconds then put it all the way up and hold for around 3 seconds then the windows should all work again from the drivers controls.
Many thanks to those that have replied.
Unfortunately there is no power to the doors. Only the drivers window is working, nothing else is working.
Any ideas anyone?
Thanks in advance,
Phil
