Rx 450h Hybrid Battery Replacement
Yes, but only partly!
.Where you see the cracked sealant by the strut mounting points & all of the dried out & broken up sealant on the floor pan in this video you don't tend to see this very much on british cars due to our milder temperature but you do see rotten & split tailgate seals.
If you do some more research you will find that the rear light cluster seal failure I mentioned originally to you is a common problem that Lexus have/are facing group class law suits about in America as it is a failure they have known about for some time & as a safety issue should be handled by the recall process IMHO
Thanks for that. I have a better idea what to watch out for. A traction Battery failure that is caused by a water leak and therefore not covered by Lexus hybrid Battery warranty would be hard to swallow. Especially that it is a fine car otherwise.
