hi all, just to ask the forum folk does the 2006 IS250 AUTO have a gearbox oil cooler ? Is it built in to the radiator ie does actual trans oil run through the radiator itself or does it take coolant to the box ?
Going to have to change my rad as its starting to corrode and wondered if it would affect the gearbox oil level .
It does but is a separate unit bolted to the right hand side of the transmission just before the bell housing.
The engine coolant radiator is just that so new rad and coolant is all that is required.
