Rx400h rear hub nut size????
Hi, can any one help? I need to replace the rear wheel bearing on my RX400h 2006. What size is the hub nut. I tried a 30mm and a 32mm (both 6 point) and the don't fit. I have read that it needs a 12 point 32mm, will this really be different to a 32mm 6 point? Thanks
